glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Jul 01, 2013Tutor
Iridabike wrote: Are you running 6.0.8? Netgear changed some stuff around and you need to patch readynasd to make it work correctly.
YES. EDIT: When you say "patch readynasd" could you be more specific? Details please, THANK YOU!
Iridabike wrote: To start with is this file present on your machine:
/run/readynasd/stats/temperature_int_deg.rrd ?
YES
Iridabike wrote: If it is then try entering this command about 10-15 times over a couple of minutes and see what happens in the graph:
rrdtool update /run/readynasd/stats/temperature_int_deg.rrd N:25:50
Trying that now. I will report back in 30 minutes. . .
EDIT: YES! I'm seeing stuff on the graph now. So what must I do to automate this process? I assume the crontab entry is supposed to do that. . .
