glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Jul 01, 2013Tutor
Iridabike wrote: To run your script:
1) cd to the directory where your script lives
2) enter the name of your script preceded by ./
With your guidance I think I just figured out what is wrong with my script. See below:
root@ReadyNAS-U4:/usr/local/etc/scripts# ./UpdateTempGraph.cron
-bash: ./UpdateTempGraph.cron: Permission denied
I'm guessing I should have made the script executable. . . Correct?
Would the command
#chmod +x /usr/local/etc/scripts/UpdateTempGraph.cronbe sufficient?
