glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
Iridabike
Jul 01, 2013Aspirant
If you type these commands :
1) cd /
2) find . | grep syslog
It should search all files for anything with syslog in the name or path
ps -A will list all processes running -try it
ps -A | grep syslogd will list any processes with syslogd in them. I am not sure if os6 has this and can't check right now.
1) cd /
