glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Jul 01, 2013Tutor
In case anyone cares. . . I finally got the graph working!
As it turns out it was likely a permissions problem ALL ALONG :oops:
Still something not quite right though. I just checked the ambient room temperature which is approximately 82 degrees F. How can the CPU temperature be 79 degrees F? As I watch the graph over time both temperatures are dropping slightly every minute. The System temperature seems reasonable. It is currently 97 degrees F. I'll keep an eye on things for a while and report back later. . .
