glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Jul 02, 2013Tutor
xmansss wrote: It works for me just fine. I hope that helps.
Dear xmansss,
Thank you for sharing your idea. Perhaps I'll give that a try after I get some sleep :shhh:
xmansss wrote: P.S.
I'm still looking for a solution on updating the values under those nice temperature and fan animations .
Well, if you do happen to figure that out, please do come back and share how you did it!
Take care,
