glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
glem
Aug 01, 2013Aspirant
Have you followed these steps with root user ?
1) install lm-sensors and fancontrol packages
2) create /etc/fancontrol file
2) restart fancontrol
May be you can try to remove and reinstall lm-sensors packages
apt-get remove lm-sensors fancontrol
apt-get install lm-sensors fancontrol
