glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
networkn
Aug 29, 2013Aspirant
I am having issues on my Pro6, I used one of the profiles here, and basically my fans keep powering up and down every few seconds. Doesn't happen in a cooler room, so I think I have my profile set incorrectly. The problem is I can't seem to find the accurate live temperatures from my device so I can change my thresholds, to stop the fans going on and off constantly. When I look under performance (firmware 6.0.8 and 6.1.1) the AUX, CPU and System are all steady at 40c, 43c and 40c respectively and NO information is available on the temperature graphcs. Is there a nice simple way I can log the true fan speeds and temperatures on my device for 5-10 minutes to work out what I need to do to fix the problem?
