glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
drfrogsplat
Sep 01, 2013Tutor
glem wrote: 20°C is not enough for ATOM mintemp cpu, and the fan always run noisy to decrease temperature. 50°C would be a realistic and better value.
Ok, I'll give a higher value a go, just enough to get it silent (its pretty good at 1800rpm and below on the Ultra 4).
glem wrote: minpwm & maxpwm are missing in your fancontrol file paste. I assume it is just a paste error.
They actually weren't saved in the file for some reason. Strange...
Also having installed fancontrol and used the above settings, it's indeed rock-solid at 34º CPU and 30º case temps, no more cyclic variation, so it does at least seem to be working more as expected.
