glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
networkn
Sep 12, 2013Aspirant
I have applied the fan fix to my Pro6 running 6.1.1 but the fan keeps powering up and down almost constantly. I took it to another location and it was fine, so it's sensing the temperature in it's normal location is too hot, and is powering the fans to keep the CPU at a constant temperature I think.
The problem is from the UI I can't see what the CPU real time temps are so I can determine how to tweak my profile to adjust accordingly.
How can I see what my temps are for real?
