glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
arnomc
Sep 14, 2013Aspirant
On my legacy Ultra2 I had false CPU temp readings exactly like drfrgosplat (serrated, like a wood saw, saying the cpu went up close to 70°C degrees).
Then I upgraded from 6.1.1 to 6.1.2 and I noticed an nice improvement in the CPU temperature reading that doesn't cause anymore the fan to ramp up to it's 2200rpm maximum (this is not documented in the release notes ; understandable if it didn't occur on ReadyNAS 3xx/5xx).
The inconsistent noise level was really annoying!! So I am now a happy OS6 user :woot:
PS: I didn't had to apply any command line fix for the temp reading neither fan speed the fan.
