glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Oct 09, 2013Tutor
revin wrote: I've installed OS6 on a pro2. As I don't have fan speed and CPU temp, I've made a small script to generate my own RRD.
First, we have to generate the cpu RRD and Temp RRD. I've created on /dashboard/frontview/stats/
and now CPU RRD:
Now it's time to create a script (update_rdd). This script gets temperature from CPU Core 0, CPU Core 1, System temperature and fan speed and updates de RRDs
So, We have the data on RRD. Now It's time to draw!. This example creates 2 simple PNGs from "now - 4 hours"
The last step it's call those scripts from crontab:
I've tried to change the images from original dashboard with this ones but it was much easier to generate a simple HTML and call this PNGs 8)
WOW revin! Your post above looks pretty cool. Any chance we could get a glimpse of your "Performance Tab" after you performed this hack? I'd be interested to see if I could do something similar on a Pro 6. . .
