glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
F_L_
Nov 01, 2013Tutor
Is this fix still needed for the Ultra series?
I just upgraded and my fans/temp seems be ok. At least they are recognized in the dashboard.
Fan running a bit slow atm though (820 rpm)
CPU is 59/138 and System 44/111
System is idle except for re-sync
