glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
vin021079
Nov 03, 2013Aspirant
Hi all,
I've just upgraded my Ultra 6 to 6.1.4. & having fan issues. i've followed all the instruction in the threads, but it doesn't work at all for me.
i've installed the lm-sensors & fancontrol, but giving me this error
Setting up fancontrol (1:3.3.4-1) ...
ln -s '/lib/systemd/system/fancontrol.service' '/etc/systemd/system/multi-user.target.wants/fancontrol.service'
[....] Restarting fancontrol (via systemctl): fancontrol.serviceJob failed. See system journal and 'systemctl status' for details.
failed!
invoke-rc.d: initscript fancontrol, action "restart" failed.
dpkg: error processing fancontrol (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up lm-sensors (1:3.3.4-1) ...
ln -s '/lib/systemd/system/lm-sensors.service' '/etc/systemd/system/multi-user.target.wants/lm-sensors.service'
Errors were encountered while processing:
fancontrol
E: Sub-process /usr/bin/dpkg returned an error code (1)
& tried to setup the config using pwmconfig & got this error:
Current temperature readings are as follows:
cat: hwmon0/device/temp2_input: Resource temporarily unavailable
/usr/sbin/pwmconfig: line 892: let: S= / 1000: syntax error: operand expected (error token is "/ 1000")
cat: hwmon0/device/temp3_input: Resource temporarily unavailable
hwmon1/device/temp1_input 0
hwmon1/device/temp2_input 0
hwmon1/device/temp3_input 0
Any idea guys? i'm very desperate & my Ultra 6 fan now running on max 2300rpm. :(
Please help me. Thanks in advance
failed!
fancontrol
