glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
MueR
Nov 06, 2013Aspirant
I'll post my fancontrol config tonight (if I remember, I'm terrible at those things). It should work for you, but if the device is idle, frontview will report the CPU at -1°C / 30°F.
