glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
sventunus
Nov 07, 2013Aspirant
Are you running a custom fancontrol/lm-sensors config? Would you care to post it here?
Curious about the difference between an Ultra 4 & an Ultra 6 concerning fans.
Thanks!
Thanks!
