glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
glem
Nov 12, 2013Aspirant
You can try to upgrade a little bit the fan speed.
Test 45 or 50 as fan speed. Change this lines in fancontrol file:
MINSTART= hwmon1/device/pwm3=50
MINSTOP= hwmon1/device/pwm3=50
MINPWM= hwmon1/device/pwm3=50
