glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
giovannip
Nov 26, 2013Aspirant
no luck :( had to stop fancontrol manually
Wed Nov 27 2013 0:31:32 Disk: Disk in channel '3' (Internal) exceeded safe temperature threshold (61 C).
Wed Nov 27 2013 0:31:31 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (63 C). Wed Nov 27 2013 0:29:35 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (405 rpm). Wed Nov 27 2013 0:29:24 Disk: Disk in channel '5' (Internal) exceeded safe temperature threshold (61 C). Wed Nov 27 2013 0:29:23 Disk: Disk in channel '3' (Internal) exceeded safe temperature threshold (60 C). Wed Nov 27 2013 0:29:22 Disk: Disk in channel '1' (Internal) exceeded safe temperature threshold (61 C). Wed Nov 27 2013 0:28:06 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (402 rpm). Wed Nov 27 2013 0:27:14 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (498 rpm). Wed Nov 27 2013 0:27:12 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (62 C). Wed Nov 27 2013 0:25:36 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (403 rpm). Wed Nov 27 2013 0:25:04 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (61 C). Wed Nov 27 2013 0:23:48 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (485 rpm). Wed Nov 27 2013 0:23:07 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (481 rpm). Wed Nov 27 2013 0:22:56 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (60 C). Wed Nov 27 2013 0:21:40 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (500 rpm). Wed Nov 27 2013 0:21:09 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (502 rpm). Wed Nov 27 2013 0:18:51 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (401 rpm). Wed Nov 27 2013 0:17:35 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (403 rpm). Wed Nov 27 2013 0:16:43 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (491 rpm). Wed Nov 27 2013 0:12:40 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (493 rpm). Tue Nov 26 2013 23:54:14 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (543 rpm). Tue Nov 26 2013 23:50:11 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (456 rpm).Tue Nov 26 2013 23:36:41 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (500 rpm).
