glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
glem
Nov 26, 2013Aspirant
Have you installed sensors.d file conf as described in this post http://www.readynas.com/forum/viewtopic.php?f=51&t=71155&start=60#p411650 ?
Are you able to see on frontview the speed of your ultra6 fan ?
Did you change the fan or is it regular fan ? fancontrol values are different for each fan.
You can see 400 or 500 rpm as fan speed in this nas log. it's not enough .... With regular fan, speed would be 850 rpm minimum to keep cold the ultra6 enclosure.
Tune your fancontrol file to have 850 rpm minimum
