glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
giovannip
Nov 27, 2013Aspirant
Hi glem,
thanks again for the help!
* yes I installed sensors.d file conf as suggested
* yes I'm able to see on frontview the speed of my ultra6 fan
* it is a regular fan
how I can tune fancontrol file to have 850 rpm minimum ? here my fancontrol file:
Best regards
G
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/it87.2576
DEVNAME=hwmon0=coretemp hwmon1=it8721
FCTEMPS=hwmon1/device/pwm3=hwmon0/device/temp2_input
FCFANS= hwmon1/device/pwm3=hwmon1/device/fan3_input
MINTEMP=hwmon1/device/pwm3=51
MAXTEMP=hwmon1/device/pwm3=58
MINSTART=hwmon1/device/pwm3=50
MINSTOP=hwmon1/device/pwm3=50
MINPWM=hwmon1/device/pwm3=50
MAXPWM=hwmon1/device/pwm3=255
Best regards
G
