glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
glem
Nov 27, 2013Aspirant
upgrade pwm3 values : for example try 70, and after 75, 80 ....
change these lines in /etc/fancontrol file
and then execute this command to override fancontrol daemon
look on frontview the speed fan ... and try again
You can also run pwmconfig (as described in the second post of this topic) to look at concordance between pwm3 values and fan speed
MINSTART=hwmon1/device/pwm3=70
MINSTOP=hwmon1/device/pwm3=70
MINPWM=hwmon1/device/pwm3=70
/etc/init.d/fancontrol restart
