glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
masammut
Nov 28, 2013Aspirant
I installed OS6 on my old version ReadyNAS Pro 6350 (MB version is Flame 6 Ver 1.1) and all works fine except that in Frontview both the fans constantly show as running at 5355RPM and Temps are as follows Aux 40degC CPU 43degC and System 40DegC
Fans seem to be working normally but the speeds are not being reported properly. Not sure about the temps at the moment.
Any tips?
Cheers
Any tips?
Cheers
