glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
masammut
Nov 29, 2013Aspirant
Glem,
I have the old version rndp6350 - will you guide me on what file I need to add in sensors.d? I suppose the ultra version is different to mine as adding the file did nothing. I even renamed it to rndp6000.conf.
Also do I need to refer to this file from anywhere else?
I have latest 6.1.4.
Sorry to be such a noob, but where do I find the name of my chip? The folder with teh fan and temps is w83627ehf.2576 on mine.
I also noticed that the temperature graph is blank.
Cheers
Cheers
