glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
renedis
Jan 14, 2014Aspirant
Can someone help me out please?
My frontview temp readings are not OK.
My fans work fine but are not showing up correct in frontview.
output of the sensors are:
And there is no file rndu6000.conf in etc/sensors.d/, only rn2120.conf with the following text:
So i've added the line to that file:
Stil the same story.. I even added the file rndu6000.conf to the folder with the text above without any luck.
My fan control file is from the PRO6, al the other settings fail and cause my CPU fan to max out on RPM.
Any help would be great!
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +44.0°C (high = +84.0°C, crit = +100.0°C)
Core 1: +46.0°C (high = +84.0°C, crit = +100.0°C)
Core 2: +42.0°C (high = +84.0°C, crit = +100.0°C)
Core 3: +42.0°C (high = +84.0°C, crit = +100.0°C)
w83627dhg-isa-0a10
Vcore: +1.14 V (min = +0.00 V, max = +1.74 V)
in1: +1.87 V (min = +0.54 V, max = +0.89 V) ALARM
AVCC: +3.22 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.20 V (min = +2.98 V, max = +3.63 V)
in4: +1.23 V (min = +1.14 V, max = +0.64 V) ALARM
in5: +1.49 V (min = +1.14 V, max = +1.18 V) ALARM
in6: +1.02 V (min = +1.70 V, max = +1.66 V) ALARM
3VSB: +3.18 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.12 V (min = +2.70 V, max = +3.63 V)
fan1: 1222 RPM (min = 28125 RPM, div = 16) ALARM
fan2: 1814 RPM (min = 1467 RPM, div = 8)
fan3: 1132 RPM (min = 733 RPM, div = 8)
fan4: 0 RPM (min = 2109 RPM, div = 128) ALARM
fan5: 0 RPM (min = 878 RPM, div = 128) ALARM
temp1: +58.0°C (high = -1.0°C, hyst = +125.0°C) sensor = thermistor
temp2: +33.0°C (high = +80.0°C, hyst = +123.0°C) sensor = CPU diode
temp3: -47.0°C (high = +80.0°C, hyst = +123.0°C) sensor = thermistor
cpu0_vid: +0.000 V
chip "g760a-i2c-*-3e"
label fan1 "fan1"
chip "g760a-i2c-*-48"
label fan1 "fan2"
chip "g760a-i2c-*-49"
label fan1 "fan3"
chip "it8721-isa-0a10"
compute fan1 0+fan3_input,0-fan3_input
compute temp2 0+temp1_input,0-temp1_input
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS= hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/device/temp1_input
FCFANS= hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/fan1_input
MINTEMP= hwmon1/device/pwm2=30 hwmon1/device/pwm1=55
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=60
MINSTART= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINSTOP= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MAXPWM= hwmon1/device/pwm2=200 hwmon1/device/pwm1=80
