glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
Jan 15, 2014Guru - Experienced User
The RN102/RN104 are OS6 only.
You can see the picture in the "performance" tab. However, the graphs are not available on the RN1xx. Per the manual:
I'm not sure why this limitation is there, but I wish it weren't.
Note: Status graphics are not supported for ReadyNAS 102 and 104 systems.
