glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
spiderman1
Jan 29, 2014Guide
Update!
I have graphing in Frontview and have been able to regulate my fans.
Here is the lm-sensors vs the Frontview readings for the fans:
Output from lm-sensors OS6
OS 4.2.25
Fancontrol file for Pro
I have done various tests and can report the following regarding OS 6.1.5:
1. OLED on Pro Box remains lit
2. WOL does not work
3. Readynas Drop, Readynas Cloud, Readynas Replicate, Readynas Remote all work!
4. Temperature graphs work (after applying fix as suggested in this forum)
5. Status animations (ie. Fans, Aux, etc.) do not work.
6. Addons work flawlessly
7. Hard drive temperatures are 8-10 degrees (i.e OS6:32c 4.2.25: 40c)
All in all, OS6 is a huge improvement from 4.2.25. Frontview boots up faster, services work wonderfully.
I am presently running a Pro with 4gigs of Ram and a Q6600 cpu.
Thanks.
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +39.0 C (high = +84.0 C, crit = +100.0 C)
Core 1: +40.0 C (high = +84.0 C, crit = +100.0 C)
Core 2: +31.0 C (high = +84.0 C, crit = +100.0 C)
Core 3: +32.0 C (high = +84.0 C, crit = +100.0 C)
w83627dhg-isa-0a10
Vcore: +1.19 V (min = +0.00 V, max = +1.74 V)
in1: +1.73 V (min = +0.84 V, max = +1.89 V)
AVCC: +3.20 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.20 V (min = +2.98 V, max = +3.63 V)
in4: +1.22 V (min = +0.38 V, max = +1.32 V)
in5: +1.49 V (min = +0.09 V, max = +0.02 V) ALARM
in6: +1.02 V (min = +0.94 V, max = +1.04 V)
3VSB: +3.17 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.07 V (min = +2.70 V, max = +3.63 V)
fan1: 1180 RPM (min = 10546 RPM, div = 8) ALARM
fan2: 0 RPM (min = 5273 RPM, div = 128) ALARM
fan3: 2311 RPM (min = 831 RPM, div = 8)
fan4: 0 RPM (min = 5273 RPM, div = 128) ALARM
fan5: 0 RPM (min = 1054 RPM, div = 128) ALARM
temp1: +49.0 C (high = +127.0 C, hyst = +125.0 C) sensor = thermistor
temp2: +35.0 C (high = +80.0 C, hyst = +123.0 C) sensor = CPU diode
temp3: +18.5 C (high = +80.0 C, hyst = +123.0 C) sensor = thermistor
cpu0_vid: +0.000 V
OS 4.2.25
Fan SYS 912 RPM OK
Fan CPU 2057 RPM
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.257
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS=hwmon1/device/pwm3=hwmon0/device/temp2_input hwmon1/device/pwm1=hwmon1/d
FCFANS=hwmon1/device/pwm3=hwmon1/device/fan3_input hwmon1/device/pwm1=hwmon1/dev
MINTEMP=hwmon1/device/pwm3=20 hwmon1/device/pwm1=10
MAXTEMP=hwmon1/device/pwm3=65 hwmon1/device/pwm1=25
MINSTART=hwmon1/device/pwm3=28 hwmon1/device/pwm1=16
MINSTOP=hwmon1/device/pwm3=26 hwmon1/device/pwm1=14
MINPWM=hwmon1/device/pwm3=16 hwmon1/device/pwm1=14
MAXPWM=hwmon1/device/pwm3=28 hwmon1/device/pwm1=22
Thanks.
