glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
arnomc
Feb 18, 2014Aspirant
Finally I tried an OS reinstall and I had same kind of temperature. Then I started a Factory Default, and I will soon see what temperature I will have.
I have look on the temps a third morning (same weather conditions) and they were in-between the first and second reading. the cpu temp is just easy to leave 35°C when complete idle, and with just 5% activity it goes fast to 42°C or more. I guess such a climb is due to the fact that it is nearly passively cooled (the only fan is not exactly on top of it). I'll leave it here as I never had the noise of the fan at full speed.
