glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
TonyKL
Mar 03, 2014Guide
I've just tested 6.1.6 on my Ultra 4.
Overall happy however my fan is running at 800rpm whereas under 4.2.26 it was running at 1800rpm.
My temp are getting quite high, is this still a problem with OS 6 and I need to manually configure the fan control??
Thanks for any advice... :D
