glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
paalj
Mar 04, 2014Aspirant
Hi,
first time post here. Great forum :D
I installed 6.1.6 on my ultra 2 and it Works very good exept for the fan Control. The fan stabilizes at 760 rpm and CPU temp is at 60C without load. I Guess this is a bit high. I tried "echo 50 > /sys/devices/platform/it87.2576/pwm1" as root and the fan went to 1500 rpm for a while, but Returns to 760 rpm within 20 minutes or so. System temp is at about 25C.
any advice?
best,
Paal
any advice?
best,
Paal
