glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Mar 30, 2014Tutor
mdgm wrote: Install 6.1.7 RC5 on your Ultra 6: http://www.readynas.com/forum/viewtopic.php?f=154&t=72282
With 6.1.7 RC5 you won't need to install or use fancontrol.
Greetings mdgm!
I've got a quick question for you in this regard. Once I'm ready to install OS6 version 6.1.7 (stable) after it is officially released, should one uninstall or undo all the fancontrol related hacks prior to installing 6.1.7 to insure there won't be any conflicts? Or do you think that the OS updater will take care of all that.
As always, thanks a million for your endless contributions to the ReadyNAS community!
