glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
renedis
Apr 08, 2014Aspirant
undo temp hacks in 6.1.6:
Installed 6.1.7 and now getting this readings:
Temp graph is also showing now.
I've installed and done this through a remote connection from my work.
So I can't really tell at this moment if the fans are running fine or full RPM without the fix.
Trying to fix the fan RPM reading this evening.
Runing:
Q6600 @ Readynos Pro 6
Edit:
Installed the "temp-fix" again.
No result in showing correct rpm graphs.
CPU temp in browser = Core0
System temp in browser = Temp1
Sensors output:
apt-get remove lm-sensors fancontrol
Runing:
Edit:
Sensors output:
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +40.0°C (high = +84.0°C, crit = +100.0°C)
Core 1: +42.0°C (high = +84.0°C, crit = +100.0°C)
Core 2: +38.0°C (high = +84.0°C, crit = +100.0°C)
Core 3: +38.0°C (high = +84.0°C, crit = +100.0°C)
w83627dhg-isa-0a10
Vcore: +1.14 V (min = +0.00 V, max = +1.74 V)
in1: +1.87 V (min = +0.54 V, max = +0.89 V) ALARM
AVCC: +3.22 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.22 V (min = +2.98 V, max = +3.63 V)
in4: +1.23 V (min = +1.14 V, max = +0.64 V) ALARM
in5: +1.49 V (min = +1.12 V, max = +1.18 V) ALARM
in6: +1.02 V (min = +1.70 V, max = +1.66 V) ALARM
3VSB: +3.20 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.14 V (min = +2.70 V, max = +3.63 V)
Rear-fan: 897 RPM (min = 84375 RPM, div = 16) ALARM
CPU-fan: 1520 RPM (min = 1467 RPM, div = 8)
Outside-fan: 1095 RPM (min = 733 RPM, div = 8)
fan4: 0 RPM (min = 2109 RPM, div = 128) ALARM
fan5: 0 RPM (min = 10546 RPM, div = 128) ALARM
temp1: +56.0°C (high = -1.0°C, hyst = +125.0°C) sensor = thermistor
temp2: +30.5°C (high = +80.0°C, hyst = +123.0°C) sensor = CPU diode
temp3: -38.0°C (high = +80.0°C, hyst = +123.0°C) sensor = thermistor
cpu0_vid: +0.000 V
