glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
renedis
Apr 08, 2014Aspirant
lm-sensors package do not have to be installed after the 6.1.7 RC5 update.
My fans are running fine now, only not showing properly in frontview.
I can't really tell if the fan RPM changes if the CPU is under load, but for now... It sounds good.
I did noticed an other failure now that I'm home.
The OLED screen works while booting and showing hostname etc. but after a short time the screen stops working.
