glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
GMulford
Apr 09, 2014Aspirant
I've just done a fresh install of 6.1.7 RC5 on a readynas pro business edition and seems to be working great. Nice to see they have invested some time into getting all the graphs etc working on the legacy devices. :thumbsup:
Only issue is the fans are now too slow, they start at about 2000 then over an hour drop to <800. The temps while copying some data are:
CPU 50c
system 65c
drives 43c
Which isn't too bad although during rebuild the drives hit >50c which isn't good. The main problem is I keep getting an email saying "Fan 'Fan' in enclosure 'Internal' speed is below threshold. (688 rpm)." Is there an option I'm missing to recalibrate the fans like on the old firmware? or a way of speeding them up a bit?
For now I may pop an extra fan on the spare fan header see if that will cool the drives.
Renedis is your OLED screen just turning off? I think it's meant to do that. It pops back up if there is an alert like sync % complete or if you press power button quickly.
CPU 50c
system 65c
drives 43c
