glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
renedis
Apr 10, 2014Aspirant
The screen was always on in the other versions of OS6.
It displayed the hostname and IP adress.
So you guys are telling me that the display should be turned of after a while..
Can't really remember if the screen turned of in OS4.
I'm trying to figure out if it is possible to fix the graphs in Frontview.
the trick with the .conf file in Sensors.D does not work :(
I have tried different settings without any succes.
Does anyone else got an idea?
compute fan1 0+fan3_input,0-fan3_input
compute temp2 0+temp1_input,0-temp1_input
