glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
renedis
Apr 10, 2014Aspirant
mdgm wrote: Yes the OLED display was turned off automatically in OS4. Momentarily press the power button and you can see the hostname and I.P. again.
I will try this when I get home.
Thank you for the information.
