glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ghostofdre
Apr 19, 2014Aspirant
yehh thanks shibby seems to be some issue with Anti-Virus on legacy boxes with OS6.
I did the upgrade a couple days ago and everything went well, except I forgot to do a factory reset so I freaked out a little when my NAS was sitting there saying "Booting..." for ages.
The only thing I've noticed is the CPU temp isn't correct. IT's sitting at 13c now which is less than the ambient room temp so guessing the sensor readout needs modding. I'm just assuming it starts around 30c when it reads 0c (actually read -1c when it booted up) and I'll count up from there.
