glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
Royan
Apr 19, 2014Aspirant
Hi.
I have just updated my Pro2 from 6.0.6 to 6.1.7.
I love that fancontrol works in this release, but it runs the fans too slow for me.
Empty nas, rebuilding volume after a factory reset, and the CPU hit's 80C (177F), and the disks are about 45C(113F).
That's a bit much for me (I know the CPU is good for it, but that doesn't mean I like it :) )
I have my own fancontrol script that uses lm-sensors and set's the /sys/devices/platform/it87.2576/pwm1 file every minute through crontab.
Will it be a problem if I set it up to run my script again?
Will my script and the built-in fancontrol compete, making the fan jump like a yo-yo? Is that a problem?
Is there perhaps any way to make the built in fancontrol a bit more agressive?
brgds
Royan
Edit: Pro2
Edit2: lm-sensors
brgds
Royan
Edit: Pro2
Edit2: lm-sensors
