glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
akrovel
Jun 30, 2014Aspirant
I've also just updated a Pro 6 for the first time from 4.2.26 to 6.1.8. I'm also getting the warning
Fan 'Fan' in enclosure 'Internal' speed is below threshold. (482 rpm)
The SYS, Disk and CPU temperature goes up and the fan speeds up, but the values are higher than on 4.2.26.
Do anyone have a suggestion on how to set a minimum speed on the fan? Is there a config file for the builtin fancontrol on 6.1.8?
