glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
akrovel
Jul 21, 2014Aspirant
I got bad news. I installed the OS6.1.9 RC8 yesterday, it seemed to be working fine and I stopped getting the fan warnings and the fan ran at ~850 RPM.
But today I got a FAN warning (0 RPM) and temperature was at 65 C. The fan started again, but I did a reboot to get it to run at 2000 RPM to cool the system down. It slowly goes down to ~900 RPM.
@Skywalker : Is there a settings-file I can modify to get this to run at ~1300 RPM as it did in version 4.2.26?
My stats used to be HDD 35-40C, SYS 40-45C, CPU 25-30C in 4.2.26 (SYSFAN at ~1350 RPM, CPU at ~2100 RPM)
Now I'm at HDD 41C, SYS 60C, CPU 45C (only showing (SYS)FAN, FAN ~900 RPM)
