glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
mdgm-ntgr
Jul 21, 2014NETGEAR Employee Retired
Do you still get the fan warnings now that it goes down to 900 rpm? It may be that a reboot is needed after the firmware update for the new minimum fan speed of 900 rpm to take effect.
