glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
mdgm-ntgr
Aug 16, 2014NETGEAR Employee Retired
RC9 (and hence RC10) has a change where if the CPU temp goes up the fan will react quickly (e.g. when you are pushing a 516 hard using Plex Media Server). If you had fan control issues due to this then RC10 should make a difference. If you had fan control issues for other reasons then it should be no different to RC8.
