glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
tijgert
Sep 07, 2014Guide
I noticed that on Ultra 6's there's an extra (unused) fan header that gives RPM indication when a fan is hooked up to it.
Is that fan then controlled or does the software *know* the Ultra 6 only came with 1 fan and thus ignores the other fan indication i.e. doesn't spool up or down with temps?
