glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
viperhansa
Oct 12, 2015Virtuoso
and all:
I have my fan running at 888-900 and cpu temp 37C/99F & system 68C/154F...
Is there a way to increase the rpms so i get a bit of better cooling?
Or should i not be concerned about the temp levels? System has gone up to 72 and cpu have also been climbing.
In frontview only 1 fan is showing. Is that ok?
regards
Hans
petermac
Oct 13, 2015Apprentice
The latest FW 6.4 seems to have broken the fan speeds on the old x86 hardware like the Pro series.
