Sandshark
Sep 04, 2017Sensei
EDA500 on RN516 - Scrub very slow
This problem has been previously reported by another user on an earlier version of the OS: ReadyNAS-516-2x-EDA500-Scrub-on-EDA500-very-slow. It persists in OS6.7.5. As scheduled, my main data vo...
kohdee
Oct 27, 2017Administrator
A scrub kicks off both a btrfs scrub and an mdadm resync. 5 disks relying on 1 eSATA connection to perform extreme recalculations on 2 fronts (RAID and FS) is very intensive and is very slow. You could move your EDA500 disks to your head unit and let the operations continue, then move them back.
Sandshark
Oct 27, 2017Sensei
Does it do them concurrently? Maybe that's the issue, but 54 days still seems like a very long time. Why would runing two processes take less CPU time than me running just one via SSH? It didn't take anywhere near that long for the orignal sync, so why should a resync take that long? I'll have to kick off another and see what /proc/mdstat says about resync progress while this is going on. Maybe the two processes are fighting over access to the same area of the array and that slows them both down, but would that not also occur on the main array?
I have to admit I did not let it complete, but I did let it go more than two days to see if it was just the reported progress that was wrong.. Maybe it would have sped up at some point. After two days, I Googled how to find the progress in SSH and that's when I found the progress shown in SSH was identical to that shown in the GUI, so I then trusted the progress report and my resulting time to go estimate were accurate and aborted it.
As far as moving the array to the main chassis for this, that's just not a real solution. I keep everything I need daily access to on the main array and computer backups and such on the EDA500 (actually, now two of them).
- mdgm-ntgrOct 29, 2017NETGEAR Employee Retired
I believe it is concurrent.
In the initial sync we can do things faster as there's not existing stuff to sync across. If you replace a disk in your EDA500 you'll find the sync to rebuild is longer than the initial sync when creating the volume.
The larger the disk capacity the longer things will take as there's more to check.54 days for a scrub does still seem like a very long time even in an EDA500.
If moving the disks to the main chassis is not practical you could find that additional main units is better than using EDA500 units for you.
I would think a volume in any of our current main units would significantly outperform one in the EDA500
- SandsharkOct 29, 2017Sensei
OK, so this is what top looks like with a GUI-intiated scrub:
top - 16:48:32 up 7 days, 22:33, 1 user, load average: 4.71, 1.55, 0.64 Tasks: 314 total, 1 running, 313 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 1.1 sy, 0.0 ni, 98.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem: 16297764 total, 15755896 used, 541868 free, 11572 buffers KiB Swap: 1569788 total, 0 used, 1569788 free. 14749048 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2006 root 20 0 0 0 0 S 4.0 0.0 0:05.13 md123_raid5 15024 root 20 0 0 0 0 D 1.0 0.0 0:00.57 md123_resync 4226 root 20 0 6344 1728 1600 S 0.3 0.0 10:42.07 wsdd2 4452 root 20 0 661376 14428 9676 S 0.3 0.1 2:00.16 zerotier-one 1 root 20 0 136976 7264 5144 S 0.0 0.0 0:09.02 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.18 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:12.67 ksoftirqd/0 5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H 7 root 20 0 0 0 0 S 0.0 0.0 2:40.28 rcu_sched 8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh 9 root rt 0 0 0 0 S 0.0 0.0 0:02.24 migration/0 10 root rt 0 0 0 0 S 0.0 0.0 0:01.88 watchdog/0 11 root rt 0 0 0 0 S 0.0 0.0 0:01.86 watchdog/1 12 root rt 0 0 0 0 S 0.0 0.0 0:01.69 migration/1 13 root 20 0 0 0 0 S 0.0 0.0 0:09.43 ksoftirqd/1 15 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0HAnd here it is is with scrub initiated via SSH:
top - 16:58:13 up 4 min, 1 user, load average: 1.90, 0.98, 0.42 Tasks: 316 total, 1 running, 315 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 13.8 sy, 0.0 ni, 86.1 id, 0.1 wa, 0.0 hi, 0.1 si, 0.0 st KiB Mem: 16297764 total, 983956 used, 15313808 free, 11252 buffers KiB Swap: 1569788 total, 0 used, 1569788 free. 565484 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 71 root 20 0 0 0 0 S 11.0 0.0 0:07.33 kworker/u8:3 1035 root 20 0 0 0 0 S 10.0 0.0 0:07.31 kworker/u8:7 1056 root 20 0 0 0 0 S 9.6 0.0 0:07.77 kworker/u8:10 28 root 20 0 0 0 0 S 9.0 0.0 0:07.83 kworker/u8:1 43 root 20 0 0 0 0 S 7.3 0.0 0:06.73 kworker/u8:2 1054 root 20 0 0 0 0 S 6.7 0.0 0:05.52 kworker/u8:9 5609 root 20 0 32168 204 16 S 3.0 0.0 0:03.04 btrfs 1777 root 0 -20 0 0 0 S 1.3 0.0 0:01.54 kworker/2:1H 4219 root 20 0 6344 1764 1628 S 0.7 0.0 0:00.90 wsdd2 1745 root 0 -20 0 0 0 S 0.3 0.0 0:00.24 kworker/0:1H 5673 root 20 0 28892 3068 2424 R 0.3 0.0 0:00.14 top 1 root 20 0 136976 7136 5100 S 0.0 0.0 0:01.51 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksoftirqd/0 4 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0 5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H 6 root 20 0 0 0 0 S 0.0 0.0 0:00.23 kworker/u8:0Here is what it looks like if I start a scrub via the GUI and cancel it (but not the resync) via SSH:
top - 17:02:18 up 8 min, 1 user, load average: 2.73, 1.85, 0.90 Tasks: 305 total, 1 running, 304 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 1.0 sy, 0.0 ni, 99.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem: 16297764 total, 1024016 used, 15273748 free, 11252 buffers KiB Swap: 1569788 total, 0 used, 1569788 free. 579124 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2000 root 20 0 0 0 0 S 4.0 0.0 0:05.24 md123_raid5 4219 root 20 0 6344 1764 1628 S 0.7 0.0 0:01.72 wsdd2 6623 root 20 0 0 0 0 D 0.7 0.0 0:01.13 md123_resync 7 root 20 0 0 0 0 S 0.3 0.0 0:00.20 rcu_sched 4680 nut 20 0 17260 1508 1112 S 0.3 0.0 0:00.77 usbhid-ups 1 root 20 0 136976 7136 5100 S 0.0 0.0 0:01.54 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksoftirqd/0 4 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0 5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H 8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh 9 root rt 0 0 0 0 S 0.0 0.0 0:00.01 migration/0 10 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/0 11 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/1 12 root rt 0 0 0 0 S 0.0 0.0 0:00.01 migration/1 13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksoftirqd/1So, yes, there is a resync in progress when scrub is initiated via the GUI that is not there when I do it via SSH. When I cancel the scrub via SSH, very little changes. If I resume the scrub with the resync still ongoing, it looks the same as if I never cancelled it. If I initiate just the scrub via SSH, then all of those kworker tasks are busy doing the scrub that are not even in the top ten processes when the resync is also ongoing. Clearly, something about having an ongoing resync is seriously affecting the scrub on the EDA500. It's not CPU availability -- the resync takes little CPU. So, it must be the I/O channel. My best guess is that the resync process is keeping the eSATA port multiplier "locked" to one drive and so the scrub process cannot access any others.
BTW, here is what cat /proc/mdstat reports on the sync:
md123 : active raid5 sdm3[0] sdq3[4] sdp3[3] sdo3[5] sdn3[1] 7794659328 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/5] [UUUUU] [>....................] resync = 3.5% (69154404/1948664832) finish=1209.6min speed=25895K/secSo the re-sync in and of itself is also not the issue, it will complete within a reasonable time (this is for an array half the size of the other, but even double this is reasonable).
I don't know the solution -- maybe doing the processes sequentially instead of concurrently. But it is definately an unacceptable situation that need attention. Any excuse that "a second NAS is a better solution" is just that -- an excuse. Netgear sold the product, and the OS should play well with it. I could accept a 3x or even maybe 4x longer task. 25x or more is just insane.
- SandsharkOct 30, 2017Sensei
OK, so I just let it keep going to see if the scrub process would speed up after the sync completes. Looking in an hour out from the resync was predicted to complete, something else had happened. Readynasd was now taking almost all of the available CPU time (it actually claimed to be 100.1%). It had a lower priority than the resync, so the resync time did not seem to be affected and it did complete when it was originally predicted to do so without readynasd misbehaving. The GUI was unavailable, but SMB access still worked. I did not test if access speed was affected. There was a scheduled rsync backup of the shares in the main volume (a pull from another NAS) which seems to have taken the normal amount of time. This could be something independent of the scrub, since I don't know when it happened, but it seems suspect since I have done nothing special during that period. Here is top at that point:
top - 13:58:44 up 21:05, 1 user, load average: 6.80, 6.60, 6.49 Tasks: 502 total, 2 running, 500 sleeping, 0 stopped, 0 zombie %Cpu(s): 3.7 us, 23.7 sy, 0.0 ni, 48.2 id, 24.2 wa, 0.0 hi, 0.2 si, 0.0 st KiB Mem: 16297764 total, 15686920 used, 610844 free, 4588 buffers KiB Swap: 1569788 total, 0 used, 1569788 free. 14518584 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 4446 root 19 -1 21.687g 93096 23968 R 100.1 0.6 760:36.66 readynasd 2000 root 20 0 0 0 0 D 5.3 0.0 57:42.57 md123_raid5 6623 root 39 19 0 0 0 D 1.3 0.0 18:58.47 md123_resync 7 root 20 0 0 0 0 S 0.3 0.0 2:08.55 rcu_sched 4219 root 20 0 6344 1764 1628 S 0.3 0.0 3:49.45 wsdd2 27931 root 20 0 29024 3336 2544 R 0.3 0.0 0:00.03 top 1 root 20 0 136976 7136 5100 S 0.0 0.0 0:02.29 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.03 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:01.15 ksoftirqd/0 5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H 8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh 9 root rt 0 0 0 0 S 0.0 0.0 0:00.16 migration/0 10 root rt 0 0 0 0 S 0.0 0.0 0:00.18 watchdog/0 11 root rt 0 0 0 0 S 0.0 0.0 0:00.25 watchdog/1 12 root rt 0 0 0 0 S 0.0 0.0 0:00.15 migration/1 13 root 20 0 0 0 0 S 0.0 0.0 0:00.75 ksoftirqd/1 15 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0HNow the resync is complete, all the kworker tasks are busy with the scrub, and the completion percentage has started to rise at a much faster pace. Readynasd also started behaving itself and the GUI is again available, so that pretty much shows that the CPU use it had was a result of the resync process. My best guess is that is was in a tight loop trying to do something that the resync process kept it from doing (probably related to the eSATA port expander) -- something that should probably have a time-out. Here is top now:
top - 15:19:47 up 22:26, 1 user, load average: 1.80, 2.89, 4.98 Tasks: 310 total, 2 running, 308 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 17.7 sy, 0.0 ni, 82.2 id, 0.0 wa, 0.0 hi, 0.1 si, 0.0 st KiB Mem: 16297764 total, 15566324 used, 731440 free, 4588 buffers KiB Swap: 1569788 total, 0 used, 1569788 free. 14627468 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 31692 root 20 0 0 0 0 S 13.3 0.0 0:40.69 kworker/u8:0 29540 root 20 0 0 0 0 S 11.6 0.0 0:43.98 kworker/u8:2 32539 root 20 0 0 0 0 S 11.0 0.0 0:45.62 kworker/u8:7 31857 root 20 0 0 0 0 S 10.6 0.0 0:43.23 kworker/u8:6 563 root 20 0 0 0 0 R 10.3 0.0 0:38.67 kworker/u8:8 31853 root 20 0 0 0 0 S 10.0 0.0 0:48.57 kworker/u8:5 4446 root 19 -1 2460276 76200 23968 S 3.0 0.5 833:53.16 readynasd 6888 root 20 0 32168 204 16 S 3.0 0.0 0:17.79 btrfs 1777 root 0 -20 0 0 0 S 1.3 0.0 0:38.08 kworker/2:1H 4219 root 20 0 6344 1764 1628 S 0.3 0.0 4:04.43 wsdd2 4312 root 20 0 227556 7080 5240 S 0.3 0.0 0:36.02 nmbd 31548 root 20 0 29024 3260 2484 R 0.3 0.0 0:01.34 top 1 root 20 0 136976 7136 5100 S 0.0 0.0 0:02.37 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.03 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:01.21 ksoftirqd/0 5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H 7 root 20 0 0 0 0 S 0.0 0.0 2:20.73 rcu_schedSo, it appears to me that the concurrent resync with a scrub causes the scrub to be effectively held off until the resync completes. The multipplexing effect of the eSATA port expander is the factor that is likely different from the main volume. This results in an initially reported very slow scrub completion rate which is going to cause the average user to think the scrub will take an eternity. So is doing a resync concurrent with the scrub (or, in practice, doing one first) really the best thing to be doing (at least on the EDA500)?
And what about the process locking out the GUI (it comes up as "unavailable")? I can see it being slow, but locking it up keeps one from seeing the scrub is still progressing (except via SSH, which your average user will not use) and may cause the user to think the NAS needs rebooting. There are several snapshots that took place immediately after the resync finished that were likely held off, but that seems reasonable. A scheduled balance on the main volume was also attempted at that point, but failed to start, presumably because of the scrub on the other volume.
