JimmyBudz
Feb 03, 2013Aspirant
Eggdrop Irc Bot
hey guys i have a problem i want my nas to connect to irc and stay in the channel so i can dcc relay files to it i have installed eggdrop # apt-get install eggdrop and it works fine but when i t...
chirpa
Feb 04, 2013Luminary
You have to make a config file, else it won't know who the master is, what channels to join, etc.
I haven't used EggDrop in a good 10 years, but there should be a default config file with it, then you can copy/modify, and use ./eggdrop -m <conf>
