dmitriivanov
Oct 03, 2015Aspirant
El capitan and time machine
Upgraded iMac to El Capitan and have problems with Time Machine .Backup begins and stops in short time
BrianL2
Oct 03, 2015NETGEAR Employee Retired
Hi dmitriivanov,
Welcome to the community!
I believe there are a lot of MAC users who are experiencing problem with Time Machine Backup in the latest OS X version. Can you confirm the model and the Firmware version of your ReadyNAS system? We will further investigate this problem and keep you posted for updates.
Kind regards,
BrianL
NETGEAR Community Team
dhillong
Oct 19, 2015Aspirant
Hi there
Im having same problem with latest OS X Elcapitan. Time machine does not recognise. Did you manage to find a solution?
Best wishes
G
- BrianL2Oct 19, 2015NETGEAR Employee Retired
Hi dhillong,
I have tested the Time Machine backup in the latest MAC OS X and it was a success. I did re-enter my ReadyNAS Time Machine credential prior running the backup. Can you confirm if you did the same? Also tell us what is the model and firmware version of your ReadyNAS system.
Kind regards,
BrianL
NETGEAR Community Team- dhillongOct 19, 2015Aspirant
Hi Brianl
Thanks for coming back. What do you mean by readyNAS time machine credential. Do you mean readyNAS credentials on time machine? My time machine does not pick up my readyNAS so not sure how I can plug in credentials. Please let me know - dhillongOct 19, 2015Aspirant
I've got a readyNAS duo 2110. Firmware 4.14
Hi dhillong,
Thanks for the information that you have provided. Try to toggle off/on the Time Machine service in the ReadyNAS admin page or Frontview then try to scan for it again in your MAC.
Kind regards,
BrianL
