krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
krylon
Mar 12, 2013Aspirant
chirpa wrote: Routers tend to do a loopback mode when talking to external IP that is really on the same LAN. I'd chalk it up to something on the router.
I've seen others in the past have issues with external access to internal jumbo frame box.
But I can host a web server on a PC with jumbo frames enabled and this problem doesn't exist, so the router is configured okay I would think
- Mar 14, 2019Retired_Member
