krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
Mar 16, 2013Guru - Experienced User
Try confirming the MTU with ping from the PC.
You do this by opening a command shell from Windows.
Then type
ping NASIP -f -l xxxx
Start with xxxx = FrameSize-28 (where FrameSize is the jumbo frame size you configured in Frontview).
If you get "Packet needs to be fragmented but DF set" then lower xxxx until that message goes away.
Then type
- Mar 14, 2019Retired_Member
