krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
krylon
Mar 17, 2013Aspirant
Jumbo frames seems to work for file transfers and shares but I can't hit the external hostname that points to the NAS, unless I disable Jumbo.
MTU is hard coded at 9000 for Jumbo frames on RAIDiator 4.2.22 x86, at least it appears that way:
ping 192.168.1.17 -f -l 8972
Pinging 192.168.1.17 with 8972 bytes of data:
Reply from 192.168.1.17: bytes=8972 time<1ms TTL=64
Ping statistics for 192.168.1.17:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
- Mar 14, 2019Retired_Member
