krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
Mar 17, 2013Guru - Experienced User
krylon wrote: Jumbo frames seems to work for file transfers and shares but I can't hit the external hostname that points to the NAS, unless I disable Jumbo.
Are you disabling jumbo on the NAS or the PC?
Also, is the "external hostname" your ddns name? If so, the issue may be in your router.
- Mar 14, 2019Retired_Member
