krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
krylon
Mar 17, 2013Aspirant
StephenB wrote:
krylon wrote: Jumbo frames seems to work for file transfers and shares but I can't hit the external hostname that points to the NAS, unless I disable Jumbo.
Are you disabling jumbo on the NAS or the PC?
Also, is the "external hostname" your ddns name? If so, the issue may be in your router.
If I disable it on one or the other (client or NAS), then it works. I can host a webserver on my spare computer with Jumbo frames and I don't have a problem accessing the ddns name from my main PC when I set the router to point to it. However, neither my spare computer nor my main PC can access the ddns on the NAS webserver with jumbo frames when the router points to it. This makes me believe there is something wrong with the ReadyNAS.
- Mar 14, 2019Retired_Member
